Discuss Rubi TX-900-N vs Rubi TX-900 STANDARD in the Tiling Tools area at TilersForums.com.
Great machine I've got the 1300 and yes it takes a bit of gettingAnd is it as good as it looks Albert with the porcelain tiles?
You don't oil, clean the rails and try dry lubeI bought the TX-900-N and it's faulty I think When sliding the cutter arm on the rails, near the top end its very stiff. Re-oiled and made no difference.
I spoke to Rubi Rep who advised WD40 the rails, clean off WD40, then use 3in1 oil to lubricateYou don't oil, clean the rails and try dry lube
Reply to Rubi TX-900-N vs Rubi TX-900 STANDARD in the Tiling Tools area at TilersForums.com
