Discuss Thickness of WALL tile adhesive in the Australia Tiling Forum area at TilersForums.com.
Jrterror
Hi.
If using a 6mm notched float to apply adhesive, once bedded, how thick should the adhesive be?
Additionally, I decided to buy a tile levelling system and I notice that the foot of each unit (the section that lays beneath the tile) is bent upward, like this -). It sits around 6mm high, so I'm thinking that dictates the thickness of the adhesive, but does that not mean that the tile is not squashing into the adhesive, if using a 6mm float.
Waluigi
6mm is far too thin for the tiles you are using if I remember correctly from your thread #85
Jrterror
They're 500mm x 300mm
Ive put three tiles on and I struggled a little. I think I mixed the adhesive to tight I struggled to push the tiles in to the Addy, I also tried to use the Vitrex Lash levelling system and the foot of each unit appears to lift the tile away from the adhesive.
The tiles also seem to have a slight curve in them to. When I look down at the adhesive behind the tiles, it's thicker in the middle than it is the edges.
I should never have started to be honest, I didn't leave enough time to do owt before I had to go out.
H
hmtiling
Lash clips are terrible. You'll need 12mm notch minimum. 6mm not suitable for that size tile unless walls and tiles are perfect and not using wedge type clips
Jrterror
I thought so. I took them out. The walls are perfect, so hoping it will be fine.
Is there information, i.e a chart that indicates minimum adhesive thickness for different size tiles?
As Harry has said, ditch the lash clip, unfortunately the worst on the market, because of that curved base plate.
Use a 12mm notch trowel as above and mix adhesive as instructed on the bag, to the correct proportions.
Trowel wall and using flat edge of trowel skim back of the tile too. Fit the tile and remove it, and check you have good coverage, if not, trowel adhesive on back of tile where it’s needed, and try again.
Make sure you have standard set adhesive and not rapid.
Mix approx a quarter of the bag to start, just till you get used to it.
And try again. :)
Waluigi
I can vouch for Protiler tools and the Premtool system. Very reasonable too. Sam @ Protiler is excellent in terms of being helpful and sending stuff out ASAFP
Also if you download he DPD App you can automatically see your parcel.
Jrterror
And try again. :)
Hi. Thanks for this. that's helpful. I've decided to use the lash system. But, need to be seen making progress tomorrow. The Mrs is getting fed up of my very slow progress with this project. So, Im gonna go ahead and tile without a levelling system since I wont be able to get a good one from anywhere tomorrow, Sunday.
I did mix exactly as indicated on the bag. The bag said 10kg requires 3.8lt of water. So, I measured out 2.5kg, using my Mrs weighing scales (don't tell her), then added it to 0.95lt of water. I then mixed it with a paddle in a drill. I suppose I should have trusted my instinct when it appeared to be quite stiff, but thought well I've measured it out exactly. Not having done any tiling before, I had no idea of the consistency required. I even used a second type of weighing scale, just to make sure my quantities were correct.
Anyway, lesson learned.
I keep thinking should I, in the morning, attempt to remove the three tiles I have done, just in case they have not adhered correctly, but worry that they'll just pull off all the tanking that I've all ready done. Especially since they'll have been on overnight. I also wish I'd not started in the shower section of the en-suite, the most critical area.
lots of lessons learnt today.
Not gonna give up though.
Thanks again
The consistency wants to be of thick wallpaper paste.
Dip your serrated trowel in to the mix and scoop up a lump of adhesive size of your fist and hold it perpendicular to the floor, it should in between staying on the trowel and slumping off. Make sense?
Don’t try to remove the fixed tiles. If they’re acceptable as they are, as there is only 3, force adhesive in all around the sides and in any voids.
If they’re on the verge of falling off anyway, then remove them.
Jrterror
3 FAll, You Are A Star! You've said just what I wanted to hear. I wish everyone else on here was as helpful. Many thanks for your help, it really is much appreciated
Just a thought, but did you leave the adhesive to stand after you first mixed it?
Once mixed leave it to ‘slake’ for 5-10 mins, (allow the mix to absorb all the water properly) then remix. It should return to the state at which it was first mixed.
It will stay useable longer, and at no point add more water, it will weaken the mix and go off quicker.
Also clean the bucket between mixes, dried adhesive on the sides will set the fresh adhesive quicker.
Reply to Thickness of WALL tile adhesive in the Australia Tiling Forum area at TilersForums.com
  • Poll
Bob Marley
