H
hmtiling
The need for an s2? You don't have to tell me. I'm not the tile police luckily for somewhy,
Discuss Bal or tilemaster ??quartz in the Tile Adhesive / Grout Advice area at TilersForums.com.
starting leveling tomorrow 100k kitchen coming 17th sept so got till 14th easy...and finishing in the one day Ray?!
why not, belt and braces i use what i trust did his partners house with same addy 3 years a go still solid as a rock was a jura cream lime stoneThe need for an s2? You don't have to tell me. I'm not the tile police luckily for some
I wouldn't put myself through the hassle of cleaning up everything after every mix. I wouldn't use rapid unless need be and certainly not s2 unless required.why not, belt and braces i use what i trust did his partners house with same addy 3 years a go still solid as a rock was a jura cream lime stone
Like nmp?board with this by by
The tiles are 93% quartz resin . It’s on concrete large kitchen floor . NO Ufh .
Was going to use uncoupling matting as well .
There is sliding patio door , don’t know how much direct sunlight comes in and for how long I’ll just have to pass on this advice to the customer and let them make their own mind up maybe they can install automatic blinds.
Hi Mark.Hi Chris, Tilemaster Ultimate would be a suitable adhesive for your intended installation.
Tilemaster Ultimate is suitable for installing quartz tiles due to it's polymer content and its low water content.
As other members have mentioned previously, the S2 properties aren't needed in your particular installation, however the low water content is something that is important when installing quartz tiles.
The premise of the product is not dis-similar to a two-part adhesive, its just that our water comes from the tap instead of the bottle of liquid.
From experience, direct sunlight can have an affect on these type of tile, so it would be best to inform the customer to try and protect them where possible - not always easy and it may never be a problem but it's better to give the customer the information so they're aware.
I hope that helps.
Reply to Bal or tilemaster ??quartz in the Tile Adhesive / Grout Advice area at TilersForums.com
