Discuss What tile adhesive to go for? in the Tile Adhesive / Grout Advice area at TilersForums.com.
L
LM
No that should be fine if it's all like that, just make sure to prime it well with atleast two coats of an acrylic or sbr primer.
R
Rhodri
Cheers. When the boards are up do they need to be primed also or just tile adhesive straight on to boards? Thanks
R
Rhodri
Have you dabbed boards on before?
Its not particularly difficult although there is a knack and learning curve to it. Getting the boards flat and plumb is half the battle. I usually do my own boarding before tiling, but had to get over a badly boarded wall recently that i would have usually just ripped off and started again. Not possible in this instance, so had to spend time levelling out with rapid set and going up a notch size. No fun :(
Sorry I only just seen this reply. No I have not done anything like this before. In at the deep end. Fingers crossed
R
Rhodri
My Mrs old man is a plasterer by trade, nowadays more office based. He said if I get a bag of bonding he will bond it and can tile straight on to the bonding. I'm not so sure? Is that a good idea?
Reply to What tile adhesive to go for? in the Tile Adhesive / Grout Advice area at TilersForums.com
