Discuss Recommended tile cutter / tools in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
JON HUME
Get the best you can afford and look after them.
It's cheaper in the medium to long term.
(and makes work more enjoyable)
My recommendations:
Sigma 3c3m will cut everything, inc' mosaics.
A decent grinder (I favour Makita) and a couple of quality blades.
A basic wet saw, vitrex (screwfix) or norton (CTD)
Set of levels (laser level not really essential but nice to have)
Stainless trowels - 6/8/10mm
Bucket trowel and gorilla tubs / BAL mixing buckets
A selection of diamond core drill bits (cheapies off Amazon will do to start)
Safety kit - specs, ear plugs, dust masks, knee pads
A decent DAB radio (essential in my opinion!)
Pencils, chinagraphs, sharpies, and a basic tool set
Thanks Impish, that's just the response I was hoping for. Cheers
JON HUME
Morning, I've picked myself up a Rubi TR 600S but am totally confused as to what wet saw to pick up.
I've had a look at Rubi and Vitrex but so many differing reviews its really hard to work out what I need.
Should I go with a wet saw with legs such as the Rubi DU 200 or Vitrex 800?
Or should I go for a Vitrex Pro 750 or Rubi ND 180 as most of my cuts will be with the Rubi ?
All your advice massively appreciated.
Jon
L
LM
Jon
What's your budget Jon?
JON HUME
Hi Lee,
Just starting out so unsure really, was hoping to spend no more than £300
Jon
L
LM
Jon as your just starting out I'd spend that budget on the following wet saw and I'd get myself a good grinder with a decent blade, you'll have change to spare and these tools will cover most scenarios for you.
vitrex-power-pro-750-wet-saw-110v-103421-
montolit-cm-115mm-diamond-blade-for-glass-mosaic-natural-stone-cm115
makita-ga4530kd-110v-115mm-grinder-in-carry-case
bosch-dry-clean-cut-diamond-angle-grinder-blade-115mm-2608615076
or
marcrist-ck850-akkumax-115mm-x-222-diamond-blade-flanged-1853011522
Albert
1,253
Gateshead NE8, UK
or
You may also need a transformer to go with your new 110v tools;)
Andy Allen
1,318
Gloucester
Reply to Recommended tile cutter / tools in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
