Discuss tile levelling system very thin grout line question in the DIY Tiling Forum area at TilersForums.com.
what
I'm considering using a tile levelling system with porcelain tiles 600mm x 300mm on both the walls an floor. The system I intend to use is the tile lash copy type (wedges and plastic clips) however I can only find ones with grout line spacing of 1.5mm,
Is that too thin for floor tiles which I have always spaced at no less then 3mm?
Could I use the levelling system in conjunction with sure tile spacers to provide a wider gap?
Are the pliers needed?
Italy
Is that too thin for floor tiles which I have always spaced at no less then 3mm? Yes
Could I use the levelling system in conjunction with sure tile spacers to provide a wider gap? Yes
Are the pliers needed? Yes
There are also 2 3 4 mm
Reply to tile levelling system very thin grout line question in the DIY Tiling Forum area at TilersForums.com
Teejay
