Discuss tile levelling system very thin grout line question in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
what
I'm considering using a tile levelling system with porcelain tiles 600mm x 300mm on both the walls an floor. The system I intend to use is the tile lash copy type (wedges and plastic clips) however I can only find ones with grout line spacing of 1.5mm,
Is that too thin for floor tiles which I have always spaced at no less then 3mm?
Could I use the levelling system in conjunction with sure tile spacers to provide a wider gap?
Are the pliers needed?
I
Italy
Is that too thin for floor tiles which I have always spaced at no less then 3mm? Yes
Could I use the levelling system in conjunction with sure tile spacers to provide a wider gap? Yes
Are the pliers needed? Yes
There are also 2 3 4 mm
Reply to tile levelling system very thin grout line question in the DIY Tiling Forum area at TilersForums.com
Dawz84
