Discuss Marcrist STC185 wet and dry cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
A
AndY mac
Hi Gary. I found if you pushed it to hard and fast it did chip. Take it slow with good water flow and it cuts clean and straight. Used it recently again on aparici glass topped no problems. I keep meaning to get a bore reducer and try and get a viper blade or similar on it. To try dry cutting.
Spud
Cheers Andy I need to buy a new rail as my one has a chewed up edge I was thinking it was the blade to be honest as I have had trouble with the marcrist said blades in the past I will see if I can get something else to fit it
P
Pro Tiler Tools
What bore reducer do you need i will get one sent out for you :)
P
Pro Tiler Tools
Andy I have a marcrist hand held saw and think it's crap I bought the rail clamps too ,tried mitring porcelain with it and it was shocking chipped the tiles badly and cut into the guide rail when the blade wandered off ,sits in my garage in the why the hell did I buy that section love to know what I am doing wrong with it any tips would be appreciated
Morning Gary, do you know which blade you have in the machine? and when you say cut into the rail did it hit the metal or just the rubber? :)
Sam
Spud
Sam
It's a marcrist turbo porcelain blade came with the machine both the aluminium and rubber got chewed when I tried to mitre with it
Reply to Marcrist STC185 wet and dry cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
