Removing efflorescence
sWe
I heard someone saying you could remove efflorescence stains with a water-white vinegar mix and a rough sponge. Has anyone tried this? It would certainly be less hazardous and less expensive than using stain removers based on phosphoric acid.
i use brick acid 😛ete
that wouldnt be too good on natural stone work or even on some soluble salt porcelain tiles when you get efforessence its normally salts coming out of the substrate due to movement of water once the floor drys out completely the efforensense normally stops
no i wouldent use it on limestone lol but great on terracotta 😛ete
Gents
Efflorescence - soluble salts that crystalise on the surface of tiling/grout.
So in contact with water some will be washed away in the rinsing process but most will dissolve in the water and in solution the salts are colourless so will disappear. they reappear on drying.
Not sure what an organic acid does to the salts (white vinegar) maybe not much
Brick acid contains hydrochlric acid and can make the situation worse.
The only way to effectively remove salts by chemical means is to use a 10% solution, in water, of ethylenediaminetetraacid (EDTA). Scrub in the solution and leave for 10 - 15 minutes. Then wash the area with an excess of clean water. The most important part of the final clean is to rinse thoroughly with clean water. Once dry the grout colour should be restored.
This process worked when I visited a property in cambridge a few years back. The conservatory grout lines were supposed to be dark brown but were very in your face "white" - it restored the grout to its originnal colour
dock
I find this product spot on for removing efflorescence....
Lithofin Cement-Away
A very strong acid for the removal of stubborn cement residue, efflorescence and heavy builders dirt. For newly laid and older non-acid sensitive tiles such as porcelain, ceramic, quarry, terracotta, slate and sandstone tiles ............
And it can be bought from any branch of CTD.........
This is a very interesting post. I am going to compose an answer for this one when i get a minute this PM
Kev
What???
You know the amount of efflorescence calls we get. I'd like a nice rounded concise explanation.
How about a nice bit of input from your good self danny on the removal of efflorescence.......:grin: ...if you gets so many calls ..what do you advise peeps to do.?.....:thumbsup:
What???
Danny,
I thought you were one of the leading experts in this field? After all in the last debate on this subject I thought you were the man who had treated 2000M2 of various substrates for efflorescence?
Why therefore do you want my concise explanation?
Kevin
Well branty go for it nothing to loose m8 when TLogistics became elite we all became equal again..........step up :lol:
tiler
From products tested in the field, we have found the removal of efflorescence on acid sensative tiles eg; marble or limestone, A q u a m i x Eff-Ex was effective. With ceramics and porcelains Lithofin Builders' Clean was effective. I carry both products in the van for these types of calls......Gaz
Danny,
Kevin
You've got me mixed up with someone else. I've never treated effloresence. I didn't know there was such a problem with it till I joined BAL.
If it is effloresence, which is not always clear from the intial call, samples are taken of the grout, and sent for analysis.
If the lab tests confirm it's effloresence, then the customer gets a remidial spec from our techincal department. A great service I'm sure you'd agree.
Here's some tips we give for removing it.
Remember, you did ask.
DESCRIPTION
Efflorescence is a crystalline or powdery deposit which forms on the surface of cementitious products. These salts can precipitate out into the surface of bricks, tiles, mortars and grouts. These deposits are chemical compounds which occur when water soluble salts forms on the surface, normally carbonates, sulphates or chlorides of calcium, sodium and potassium. In Portland cements, the most common form is calcium carbonate.
This is a phenomenon which affects the whole of the building industry. In ceramic tile installations, efflorescence takes the form of a whitish deposit which often manifests itself on the surface of the grout lines, most frequently in flooring applications. Visually this will often take the form of a surface stain discolouring the pigmented floor grout during the setting or drying out period, creating light and dark ‘patchy joints’.
In itself efflorescence is not damaging to the grout and the effect is purely aesthetic. Efflorescence is usually encountered in new or recent constructions and is often more likely to appear at certain times of the year in the UK i.e. during colder temperatures.
CAUSE
For salts to form there must be the presence of the three following elements.
  • Soluble salts present in the substrate or cement.
  • Water must be present.
  • Evaporation or hydrostatic pressure, or other force to cause the water and minerals to the surface.
The amount of efflorescence that occurs is related to factors such as:-
· The amount of water present i.e.
- Adding too much water to the grout during mixing.
- Over washing the grout joints with water during the cleaning off process.
· The amount of available soluble salts (normally calcium). and
· Drying times (which are extended in cooler temperatures).
Note: The colder the air temperature, the colder the backgrounds and bases. For any construction material containing cement, the rate of cement hydration and the rate at which residual moisture is lost will be decreased (slowed down), the colder the site temperatures, particularly at temperatures below 10°C. Please also note that BS 5385-4 does not recommended tiling below 5°C.
The longer the moisture is present, the greater the chance of salts dissolving in it and permeating to the surface as the mortar and grout dries out. This is particularly prevalent in any system which contains grey Portland cement.
PREVENTION
To prevent efflorescence from forming you need to eliminate as much as possible any of the above elements.
a) In ground bearing installations, it must be ensured that where possible a suitable vapour barrier is positioned on the sub-floor in the form of a surface DPM (damp proof membrane) which is compatible with the adhesive.
b) There is no moisture trapped within cavities or the sub-floor allowing salts to migrate from the background. The drying time of the grout joints is not extended by covering with polythene or similar material.
c) There is no excessive water being added to the grout which will cause the migration of natural salts within the cement to the grout surface.
BRITISH STANDARDS
BRITISH STANDARD BS 5385 : Part 3 : 2007, the code of practice for the Design and installation of internal and external ceramic and mosaic floor tiling in normal conditions states in Section 11. Cleaning and maintenance
11.3 Efflorescence
“Efflorescence is aggravated by excessively damp conditions following installation or prolonged delay in drying out and may be persistent if it is due to rising moisture where damp-resisting construction (see 6.5.2) is inadequate. The deposit should disappear with washing but may reappear after drying; it should diminish with progressive washing and the most effective treatment is to increase the frequency of washing until the deposit ceases.
Persistent deposits may be treated with appropriate proprietary acidic cleaners, but in such cases the floor should be wetted and the free water removed before the application of the cleaning agent. It is important that this treatment is followed immediately by thorough rinsing with clean water.”
REMOVAL
Efflorescence can normally be removed by washing down with clean potable water. This may need to be repeated where the deposits are light to medium.
Where the salt deposits are heavy they may be removed by the application of a suitable acidic based cleaner such as *Lithofin Builders’ Clean :-
· Pre-wet grout surface with water
· The product can be diluted up to 10:1 with water, however dependant upon how heavy the deposits are, use at a stronger concentration or undiluted, if required.
· Apply with a stiff bristle brush (scrubbing brush) or emulsifying pad and distribute immediately.
· Leave on the surface for up to 10 minutes, but do not allow to dry.
· Work cleaner into grout surface again.
· Wash off with plenty of clean potable water.
· Repeat where necessary.
*NB do not use on polished and honed limestone, marble tiles, concrete stone, terrazzo and hard stone not resistant to acid. Use a suitable non-acidic cleaner i.e. ******* Eff-Ex or equivalent Lithofin product(s).
Thanks for the input Danny....spot on advice there..........nice long reply just as we like them...........
:yes:
I believe that Eff ex is not for a long term cristalized efflorecent situation but more of a quick cure to efflorecence when it starts showing itself. I know it is written to protect from further efflorecence which would then make it a cleaner/sealer would it not.
Lithofin Builders clean is as you say good when working with manufactured tiles as its acid, for natural polished, unpolished then Power clean which is alkaline would be good.
tiler
we used to use diesel on quarry's but that was an sites i would,nt recommend in in a domestic situation
The main emphasis regarding efflorescence from both BAL and Mapei viewpoints seems to concentrate on the grout issues.
The effloresence problems that I deal with mainly apply to the natural stone I have been asked to Grind, Hone, Polish, Clean, Restore or Repair.
There are usually large areas involved. The most important factor regarding efflorescence is to find the cause because if you can't find that it will just keep reoccurring. Once I have found the cause provided the efflorescence is not too old (by this I mean hardened) the easiest and quickest removal method I find is to make a wire wool pad and use that. After all you need water to create efflorescence so if you dont use any it can't be created again. Failing this i.e. the salts have hardened or the wire wool has no effect I try various products i have at my disposal according to what material the efflorescence is on. I have in the past resorted to grinding it off. I then clean & treat accordingly with Eff Ex and Hey Presto:thumbsup:
Kev
Kev
With all due respect I think your selling us a kipper here.
Efflorecence is created as moisture with salts evaporates. It is found on the surface, those who know building will of seen it repeatedly on old external walls without cavity as they dry outwards.
Moisture and salts come from within, precipitate out and as the solution evaporates the salts crystalise.
With a tiled floor if you wet it then the situation isnt agrivated as the grout is water resistant. To agrivate it the water would have to travel through as far as the sub floor mix with salts then precipitate back out. Its a contradiction water resistant grout / water penitration
BRITISH STANDARDS
11.3 Efflorescence
REMOVAL
There are chemicals available to inhibit, remove efflorecence as mentioned but honing gringing etc etc to get rid of it................Sorry m8
tiler
How do you become an elite member?
You need to be a member who is known for contribution quantity and quality and are very Pro-TilersForums.
Respected members with experience and knowledge of the trade such as Fekin, Gaztech,Grumpygrouter, sWe and others who's words you can trust m8
They are chosen
tiler
Efflorecence is created as moisture with salts evaporates. It is found on the surface, those who know building will of seen it repeatedly on old external walls without cavity as they dry outwards. We are not talking buildings we are talking about floors
Moisture and salts come from within, precipitate out and as the solution evaporates the salts crystalise. What Solution?
With a tiled floor if you wet it then the situation isnt agrivated as the grout is water resistant. To agrivate it the water would have to travel through as far as the sub floor mix with salts then precipitate back out. Its a contradiction water resistant grout / water penitration Who mentioned tiled floors?
BRITISH STANDARDS
11.3 Efflorescence
REMOVAL
tiler
Tiler,
Your posts are well out of order along with your insinuations. Nobody is selling you anything. All you have done is requote what I have already said and then called me a liar and furthermore I am not your mate either.
Everything I post is work I have done. I have treated efflorescence on a large scale both in this and other countries. I have had to resort to grinding calcified efflorescence from the surface of tiles in a listed building where the floor had to be restored so which part of that don't you or won't you believe.
You cannot get efflorescence on tiled ceramic floors it only occurs in natural materials where the water or moisture as you quote drive the salts through the pores to the surface. That cannot happen on ceramic and vitrified tiles with the exception of the surrounding grout.
How much serious efflorescence if any have you treated? How did you/would you treat solid calcified efflorescence? Lets say 20 years old for example!
Kev
They are chosen
tiler
You should apply then
I havnt called you a liar and I call everyone m8 what I have done is create a little doubt over your statement re efflorescence. You present us with two statements which raise some question as to your understanding despite it having been quite clearly stated by authority. Following these statements you tell us of grinding etc which is at the very least extreme and rare as you can only quote 1 instance in your 12-18 month of repairing floors.
Kev
That would aggravate the problem I am afraid. Water is the driving factor and the main cause of Efflorescence:thumbsup:
Kev
BRITISH STANDARDS
REMOVAL
The most important factor regarding efflorescence is to find the cause because if you can't find that it will just keep reoccurring.Kev
BRITISH STANDARDS
CAUSE
Hopefully this information will be of use to and if I come accross a stone floor with surface damage resulting from efflorecence I will indeed call in the professionals as I dont have the kit to grind.
Do hope this clears up my previous post which wasn't written to encourage such an outburst mearly to try and get through to you the 2 points outlined above.
tiler
They are chosen
tiler
That rules me out then. :yes:
the post where tiling logistics said he has removed effloresense by using wire wool pads and grinding the floor back is GOOD ADVICE he was talking about natural stone, some marble and granite with effloresesnse problems CAN sometimes be sorted out by cristallisation
i dont know any of you lads on this forum but the fact you spend your free time researching new methods and talking to each other about the trade suggests that you are good tradesmen and therefore you shouldnt dismiss what another experienced bloke has to say stop argueing about a subject which is so contientious there is not any true guaranteed method of removing effloressense and every situation where it occurs is never the same as any other
Thank you for that halt on things !!!
Re your post :
But if you use cristallisation on floors exhibiting efflorecence you will then make your problem worse by leaving yourself open to spalling wont you ??
tiler
sWe,
Dan,
sWe,
Dan,
