Discuss Largest floor tiles laid in the Canada Tile Advice area at TilersForums.com.
Tommygun_ski
Hi guys. I am trying to find information about the largest floor tiles that was ever laid in Britain. Anything bigger than 3m x 1m and standard 10 - 12mm thick. Thanks for your help. Thomas
White Room
At that thickness you'd be struggling to fix unless helped with a support system and about 6 burly helpers.
Tommygun_ski
I am just curious if anyone laid or seen anything bigger than this as we were told those tiles are the largest format ever laid in Britain so far. I don't want to take a credit for that as I heard someone is manufacturing even larger format but only 3.5mm thick. Those iles are 3.2 x 1.2 m and 12mm thick. Each weight around 240kg. This is extremely dense porcelain with nano glass reflective finish layer. We did fix them using only suckers without any frames. Leveled with rubi tile level quick and cut with flex cs60.
Tommygun_ski
Do you want to see how they were lifted up the first floor? We have now on the floor 6 tons of tiles and a ton of adhesive.
Colour Republic
Neolith have slab sizes of both 3.65 x 1.25 and also 3.2 x 1.5. I've never laid that size but i've seen it done, in the UK too. Yours are pretty close and a lovely job, but sadly you were told incorrectly. Although don't want to take anything away from you pal;)
Reply to Largest floor tiles laid in the Canada Tile Advice area at TilersForums.com
