Discuss Hardiebacker in the Canada Tile Advice area at TilersForums.com.
macten
1,158
Nottingham
Hardi rep told me if primed it is totally water proof and suitable for wet rooms (assuming joints are sealed).
Not done it myself but that is what Hardi say.
macten
1,158
Nottingham
It wasn't the Hardi rep it was the NMP rep -I get them mixed up.
Insisted with their primer NMP is perfect for wetroom installations.
H
hmtiling
i wouldn't trust it though and doesn't say it anywhere,that i can find, in their bumf.
Stef
I've not used nmp but it's basically the same as Hardie, a cement board.
There is no way that is deemed waterproof using their primer.
The only boards that are waterproof are the poly extruded ones ie marmox, wedi etc.
SJPurdy
from "no more ply" document:
SJPurdy
"To make NO MORE PLY boards completely waterproof, coat the completed NO MORE PLY surface with two coats of SBR primer (one part SBR to three parts water)."
I've done this in the past and not worried about it but I did like to use a secondary tanking tape in critical corners to back up the glued joint.
However I would always go for Wedi in preference to it on walls for the reason given in my earlier post.
Sorry my post got split (finger on keys trouble)!!
Reply to Hardiebacker in the Canada Tile Advice area at TilersForums.com
  • Poll
