Discuss Mosaic Borders/bands in the Australia Tiling Forum area at TilersForums.com.
L
LM
I was wondering what way would you guys would price splash back panels behind sinks that stop approx 250mm from the floor and ceiling, which consist of 300x600 tiles on their side with a band of thinner mosaics which need to be screeded flush obviously with the tile, either side and the whole lot trimmed with L shape aluminium trim and then above the bath wall again 300x600 on their side but with two vertical bands of mosaic again screeded flush. All work on building sites multiple units? Any input will be appreciated, thanks.
L
LM
To be honest I can easily do one of the sink panels in an hour, which to me would mean I wouldn't be charging the builder enough for what they'd be getting
SJPurdy
Is that true in practice though?
You put up the column of 600 x 300 tiles (easy) (include drilling for pipes?)
Then fix trim in position,
then screed between trim and fixed tiles to leave thickness of mosaic and thin bed of adhesive;
Then wait for that adhesive to set!!!
Then fix mosaic;
Then when that has set grout it.
Ok if there are several ready to be done and you can flit between them, doing different stages, so you have constant work.
Spare Tool
Would it not be easier to use a mosaic mesh backing sheet, cost more overall than dog tooth method but much less faff..
L
LM
Then fix mosaic;
I don't wait for the adhesive to set before fitting the mosaic, I screed or "dog tooth" to a depth that allows the mosaic to be patted into the adhesive, which is a tight mix, although just wet enough to still have transfer onto the sheets of mosaic, but stiff enough to hold the weight , which to be honest isn't that much. Then if I'm honest I don't get the grouting done in that application, I carry on with other work in the house and come back to the grouting at a later stage, but the grouting of a panel only takes about five minutes anyway. I spread a bit of adhesive to the back of the trim and hold them in position with a pin at the outer edge of each corner and a couple down the length and remove them before grouting, incase you where wondering how I managed to dog tooth with trim that hasn't set.
L
LM
I find the way I do it is quick and efficient and you still have to screed a certain depth for the mosaic and plastic sheet anyway, I'm very satisfied with the final product that I leave, it's a solid job that looks spot on every time, I'm just wondering if I'm charging the same as what you guys would charge for a similar end product. Other guys I know can take up to two hours, or if their leaving the bed for the dog tooth to dry, even longer to do the same job as me, I've just got my procedure down to a tee.
Reply to Mosaic Borders/bands in the Australia Tiling Forum area at TilersForums.com
  • Poll
