Discuss Trowel Size For Porcelain Floor Tiles in the Australia Tiling Forum area at TilersForums.com.
L
Leon632
Hi all. New to the forum.
I'm doing my first tiling job in our hallway.
I've got the sub floor nice and sturdy by gluing and screwing hardibacker down but need some advice on the trowel size for the job.
The tiles are pretty small. They are hexagonal and roughly 26cm x 21cm rock solid 6mm Porcelain.
What would be the best trowel notch size to use? I've read 10mm for floor tiles but that is obviously a fair bit thicker than the tiles themselves.
Your advise will be very much appreciated.
Hi Leon Welcome to the Forum!
Remember, using the flat side of the trowel, put a skim of adhesive on the back of the tile first before bedding down!
This is a very important part of the laying process when it comes to Porcelain.
Use a trowel that produces ribs that are deep enough so that when u bed the tile it gives u a solid bed (full coverage) if your floor is flat enough try a 8mm trowel with 6mm tiles. Then lift the tile and see what the coverage is like. You're looking for coverage like this;
L
Leon632
Thanks for the speedy reply. I have a 9mm trowel so I'll give that a go. Funnily enough i was after a 8mm one but they didn't stock any.
I'm just hoping my tile cutter cuts the tiles ok now.
I bought a sigma after reading good reviews. It glides through and snaps any ceramics I throw at it but these porcelain are rock hard. If I apply a lot of pressure on the score and snap it just gets through it cleanly.
Unfortunately I'm not a Sigma user so I can't really comment.
Most slide cutters have a certain technique to them, but generally speaking it's more of a snap movement when breaking, that's is to say a short sharp snap movement, but u don't actually go thro the tile, if that makes sense :)
Mr Tiler
Sigma wont be problem if there is it is probably the person cutting
L
Leon632
Thanks guys. Like i say i practiced on one of the tiles and got through it with a quick hard tap.
Where is the best place to tap the tile?
Reply to Trowel Size For Porcelain Floor Tiles in the Australia Tiling Forum area at TilersForums.com
