F fastcam Aug 15, 2008 #1 I realise that i have to prime newly plastered walls,not with pva.I intend using granfix adhesive as i find it very good.Which primer should i use?
D DHTiling Aug 15, 2008 #2 No not pva..... when you say granfix....is it a dispersion or cement adhesive..?..
G grumpygrouter Aug 15, 2008 #3 Need to be a bit careful with Granfix......they specify PVA as a primer with some of their adhesives :whatchutalkingabout
G GazTech Aug 15, 2008 #4 fastcam said: I realise that i have to prime newly plastered walls,not with pva.I intend using granfix adhesive as i find it very good.Which primer should i use? Click to expand... A synthetic or acrylic primer is the most suitable....Gaz
K klaatu Aug 15, 2008 #5 hi mate granfix have a table you can get it off there site will give you all the info you need
B brian c Aug 15, 2008 #6 GazTech said: A synthetic or acrylic primer is the most suitable....Gaz Click to expand... im with GAZ on this one.
F fastcam Aug 15, 2008 #7 Thanks for all the replies guys.I'll look into A synthetic or acrylic primer tomorrow
W Wylie TF Aug 16, 2008 #8 grumpygrouter said: Need to be a bit careful with Granfix......they specify PVA as a primer with some of their adhesives :whatchutalkingabout Click to expand... So does larsen
