H
hn101
Hello, I have been repairing a shower which is as follows: raised wooden base with 15mm plywood floor for shower (no tray) covered in porcelain floor tiles 25cm square. The cowboy who originally installed it had some of the floor tiles sloping away from the waste causing water to sit in the corner and eventually after about 6 months the silicone would fail and start to leak. I decided to fix the problem by lifting the incorrectly sloping tiles and refix using BAL fast flex so they all now slope the right way. I didn't have time to finish it myself so called a tiler in to clean off the excess adhesive and grout them. I left a bottle of GT1 admixture and BAL wide joint grout powder for him. When I got back 3 days later I found that he did not use the admix. Not only that but the grout is very powdery and can be scraped away with your finger nail. Even without the admix I expected that the grout should be hard after 3days as it is totally dry. I don't want the shower to leak again nor do I want water to be absorbed too much into the plywood below, so i'm planning to scrape the old grout out and re do it carefully measuring the right quantities.
Could someone tell me why the grout the tiler put in is so powdery and whether I should re do it with BAL WJG. Is it going to be robust enough for the shower or should I use something else e.g. epoxy.(this is my first time tiling) Thanks. Do you think he deserves paying?
