Discuss which self levelling ? in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
L
LJD
Going to rip up a tile floor this weekend. I am going to raise the whole level as the bedroom (ensuite) floor is higher .The idea is to remove tile . prime as required and self level .Then apply a matting , then tile etc to match height .So i need a SL that will be able to take tile adhesive after 24 hours if possible and to be about 6-8 mm thick .
or any other options ?
Dumbo
Most levellers will do that as long as you don't overwet it which will slow down drying
Blunt Tool
Weber fibre enhanced self level screed or Mapei renovation screed both excellent and available at most good tile shops CTD etc mix as directed and will be dry ready for tiling next day. Good price aswell
Ttt1601
If 5his is a diy project and you don't jave much experience with levelling compound, I'd recommend a 2 part as it will ensure you get a consistent mix and a good flow rate, I use ultra tile products a lot and their, level it two, is a very good product is highly recommend
L
LJD
I have the Mapei renovation ready ! Tiles up tomorrow and then primed and by end of day the Level compound can go down . Ready to continue Monday .
Albert
As above,most levellers can be tiled on after 24 hours.If tiles are solid why not stick backerboard or hardi on top to bring up the level
Reply to which self levelling ? in the Adhesive and Grout area at TilersForums.com
Apatel
