Discuss Which dry disc for 115m grinder. in the Canada Tile Advice area at TilersForums.com.
Hi guys, the title says it all really. I don't have a wet tile saw so looking for good quality one blade. Also, some hole saw cutters. Is it best to buy cheap and use once and throw and buy decent ones.
Thanks guys. Hope you have a good day
Sean Kelly
One stop shop @ ATS.
G
GoneGuy
I’ve got a few different blades, montolit dna, premtool and a few from ats.
It all depends on what material you are cutting as some blades are better for ceramic than porcelain
I
Italy
one for all is quite adel ....
I used to think like you before,
I have changed my mind a few months ago, one is enough.
but I miss the test with thin porcelain :)
With these blades running dry, can you still get a neat cut on the angles for a wet room former or is there slight chip out on the edge?
Reply to Which dry disc for 115m grinder. in the Canada Tile Advice area at TilersForums.com
  • Poll
Teejay
