Discuss Wetroom help plywood floor in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jackk
Hi I will be ripping a bath with shower out and want to replace with a wetroom, I want to keep a level floor throughout the bathroom I am not wanting to buy a tray and plan to make one out of plywood I know this can be done if ranked correctly. I am just wanting to know how to get the slopes right and how to set out the timber to carry the weight and not have any movement once completed. I have searched a lot about this and can’t seem to find much apart from cutting the joists down is a good idea. Any help to at all or links to other threads on this is appreciated.
Dumbo
Don't do it , it not reliable , plywood moves with temperature changes and moisture changes , it will probably fail .
Jackk
ply wood with correct falls/slopes with all joints feather edged then siliconed round, then a layer of backer boad with joints filled/primed then waterproof sheeting and more tanking then tiled surely this would be fine?
I have read a lot of mixed reviews on this I will not be buying a tray for £200-300 + it’s not an option for me
J Sid
Sponsor on this site
Other makes available, do some research
Ajax123
My wet room tray cost me £90 120mmx120mm 10mm fall to drain. The ply plus bits system you are talking about will probably cost more be more work and will probably fail
Jackk
Okay thanks for the replies I will be buying a tray the wet room will be 1m wide but the length is going to be around 1.7m I will buy a tray 1m x 1m what can I do for the 700mm left of the floor space?
J Sid
I'd by a tray bigger, say 1800x1000 and cutting down if needed and also ordering a 20mm board of the same type as tray to board the whole room for level access ready for tiling
Ajax123
when I did mine I bought an extender board (basically a 20mm cement faced foam board matching the wet room tray to take it out to 1.2 wide by 2.0 long. whole thing including screws I think cost less than £250 including the backer boards for the walls. cant remember the make I used but it was blue foam with cement facing. I sealed the edges together with MS polymer adhesive. (sticks like sh*t rapid from screwfix)
Reply to Wetroom help plywood floor in the Canada area at TilersForums.com
Apatel
