Discuss Wet Room Floor Advice Please in the Australia Tiling Forum area at TilersForums.com.
E
EdinTiler
I have a friend that's building a wet room at the moment. He doesn't want to use a formed tray but just wants to make the floor in its entirety. This will comprise of a run from one end of the room to the drain end. It's a linear drain that he plans to have roughly 30cm from the shower wall. The room is 2.2m in length. It'll be framed appropriately and topped with 18mm ply.
Can someone tell me the run/gradient that'll be needed from entering the room to the drain please. The walls will be Wedi board that's taped and tanked. I'd also like some suggestions about what I should do with the floor before tiling it.
EdinTiler
Thanks in advance
E
EdinTiler
Change of plan. The drain is goin against the wall at the bottom of the run. All I can find from Schluter is a 2% gradient, which over 2.2m would be 44mm. I don't think this seems enough. Anyone got any suggestions. I hate workin for friends that won't listen. I want then to put an entire Schluter system in but they're havin none of it.
EdinTiler
E
EdinTiler
Guys I don't have much say in how he goes about making the floor. One thing I'm sure of is that it'll be solid and fit for purpose. He's a joiner which is what makes this harder than ever to explain to him. Thinks he knows everything. I'm only tiling it as I've suggested the proper way to go about it and he wants to do it his way. It's out of my hands unfortunately. I'll be taking no responsibility other than the tiling. He knows this. Fed up of trying to make him see sense.
@impish Tell me why this is a guaranteed fail please?
EdinTiler
One Day
EdinTiler
I've attended loads of failed wet trays and showers which have had timber or hb 'custom' made floors. Aside from the smallest of failures in waterproofing causing failure, the link between the drain assembly and the floor is the real weak spot. Far safer to use a tray with the drain assembly built in and all watertight. Plus the tray itself is inherently waterproof.
E
EdinTiler
This is a brand new floor being built in a room that was a boiler room Impish mate. As I said the one thing I know is that it'll be solid. Mike Holmes solid, overkill.
As stated previously, I have made him aware of all of the above and he still wants to do it his way. Nothing I can do about it. He's gone and bought a wet room linear drain and trap etc. and his plumber says it's no problem to fit so my hands are tied.
It's just another case of 'what does the tiler know' unfortunately.
EdinTiler
Reply to Wet Room Floor Advice Please in the Australia Tiling Forum area at TilersForums.com
