wetdec
imo over that way you know you have an absolute bond between floor and membrane. As has been said either is ok................
Discuss UFH and decoupling membrane which way round in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
The Durabase I have is an uncoupling membrane a bit like a sandwich of thin plastic with raised discs on one side, bought it of someone on the forum, may even have been you Wetdecs. All I need to know really is do I fit the ufh first then slc then durabase then tiles or is it durabase ufh slc then tiles, I have two conflicting sets of advice and to be honest it makes sense to me either way. Thanks to all contributors so far.
Either way Stevoe mate, Gerard from Dural will confirm this.If you need his mob no. PM me or post again here. Ci is de-coupling WP primarily tanking
Durabase Ci Suppliment.
CI Matting – Underfloor Heating Systems
The increased stress within the installation caused by thermal movement can cause problems to the installer. Separation or Isolation Membranes are ideal for removing shear stress from tiled installations. This removes a major obstacle to fixer confidence in installing these systems.
By absorbing this stress the membrane allows the tiled surface to remain intact. The air spaces under the membrane have two benefits, they allow residual moisture to gradually escape therefore helping to prevent cracks forming in the substrate. The air spaces also allow the heat to be spread evenly across the floor surface making the heating action more general and effective.
CI matting requires no special precautions when used within a heated installation.
The only requirement is the selection of an adhesive suitable for use with the substrate. This adhesive must be capable of bonding to the substrate and achieving a mechanical fix with the fleece on the underside of CI matting.
The electrical heating elements should be installed onto the surface of the CI matting following the manufacturer’ instructions. Standard thin set adhesive can be used to fix tiles in place. A modified flexible grout should be used to complete the installation.
so do you stick the heating mat direct to the top of the ci and then flood with slc so as it fills the cavitys in the ci and then goes over the top of the matt? if you wern't using slc and decided to just tile direct onto the heating mat then wouldn't it be very difficult to force the adhesive threw the heating mat and being able to fill the cavitys in the ci? ensuring the cavitys are full? or would you suggest filling the cavitys in the ci first with tile adhesive allow to dry then heating matt then slc or just tile? I have done it the other way matt slc decoupler then tile and never had any issues. I have always thought that by doing it this way that any expansion caused by the heating matt will not affect the tiles due to the decoupler being between them. But it seems i could be wroung..
Reply to UFH and decoupling membrane which way round in the UK Tiling Forum area at TilersForums.com
