Discuss Trim Removel from existing tiled wall in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Wishiwasatoptiler
Hi peeps
Looking for tips. Heading to look at a job which is a new build that was part tiled by builder, customer wants remaing area tiled. There is plastic trim fitted. Any tips on removing trim with damaging tiles fixed on.
Cheers
L
LM
Get a clean stiff scraper and place it in between the trim and tile and gently and carefully keep tapping it upwards along the length of the trim, chances are if your careful enough it’ll come out ok. If not get a heat gun and gently heat it until you can bend it back and then cut it off with a Stanley knife.
Wishiwasatoptiler
My gash by stanley:D
Reply to Trim Removel from existing tiled wall in the Canada area at TilersForums.com
Lowpaul22
