Discuss Travertine On Walls in the Canada Tile Advice area at TilersForums.com.
H
Handyandy2
Can anyone advise on fixing 60 x 40cm travatine to wedi wall board in a shower area.
I now it needs to be white was thinking of using a d2, thanks
SJPurdy
you want an s1(flexible) white adhesive. back butter stone also.
Yes definitely white cement based not dispersion.
S1 ( flexible/slightly deformable) is fine but I would have thought just C2 flexible would be sufficient (not criticising just looking for confirmation/other opinions).
Being stone should it not also be rapid set so that any salts are locked into the setting mixture quickly preventing them moving into/through the stone?
H
hmtiling
I, personally, would use an s1 with any backer board and stone and using standard or rapid wouldn't concern me with travertine.
Reply to Travertine On Walls in the Canada Tile Advice area at TilersForums.com
  • Poll
