top row of tiles leave uneven gap by ceiling
U
Unregistered
Am having tiling done in the bathroom. The tiles are now all up, although there is an uneven gap where the top tile meets the ceiling (ranging from half an inch to 2 inches). I am told this is because the ceiling is not level. Our tiler is suggesting we put coving to finish it off to conceal these gaps but I don't think this is going to look too good as the tiles are very modern & coving would look out of place. I would be grateful for any other solutions or ideas. I have spent loads of money on these tiles and getting bath replaced and now left with this rubbish finish... help
If you register ( it's free ) you will be able to reply without having to have your posts approved and also you might be able to show us some pics of what you have...but it sounds like your tiler hasn't set out the datums propperly..
Obviosuly its hard to say whats happened without seeing the walls, but it sounds like they havent been set out properly, has the tiler started with a full tile from the floor, they should have been set out with cut tiles on the top and bottom rows to make sure there was no gap. Sounds lilke he's started and finished with full tiles.
The tiler should have gauged the tiles so that does not happen. You have to take into account the size of the tile, to where they are going to fix, ie, a good cut as your asking to the ceiling, to the windows, to the bath , boxing in etc, once this has been set out there should not be a problem. In other words, bad setting out by the tiler!
If it is a modern house I cannot beleive the ceiling is out by 1 1/2 inches from one side of a bathroom to the other. Have you put a spirit level on the ceiling and then on the tiles to see if they are square on the wall?
Your tiler should have set out with the ceiling running off in mind and cut up to the ceiling. Either filling the small gap left (1-2mm) with flexi grout or culk. Half an inch is way too much and 2 inches is totally unacceptable.
Where did you get your tiler? How did he set out the room?
If its an old property and suffered bomb damage during the 2nd World War ie up to 1945, you may well have this amount of difference!
Apart from that it may be that he didn't deem a raking cut aesthetically appealing and decided to finish on a full tile.
Or he may have just made a right mess of it and wasn't worried about getting paid - I'am assuming you've witheld his money!
Timeless John.
PS - If the tiles are level you could always have the ceiling lowered and replastered.:thumbsup:
thanks for the replies. will go and take some pics and come back bit later & register. I think they started tiling near the floor - i remember seeing some sort of wooden baton going around the room and they started tiling above that. The ceiling used to have wooden cladding so I asked them to take it off and replaster / skim the ceiling.
There has been a number of people in there working together - plasterer / tiler / plumber headed up by a guy that was recommended to us. The tiles are level so I presume they did bodge job by not ensuring ceiling was level before tiling. I agree that lowering ceiling is best route - although sounds like a hassle as it has been painted and spotlights are in. Do I have any other options? Someone suggested using the same tile as a border at the top of the wall.
Timeless John.
Or he didn't have the skill to cut tiles on an angle?
Unregistered,
Colour Republic,
Unregistered,
Colour Republic,
