Discuss Tiling Around Odd-sized Tub Space With Ledge in the Canada Tile Advice area at TilersForums.com.
K
Kevin Hackworth
I'm looking for ideas on what to do with this ledge I need to tile. The space is too long for any tub size I can order so I had to put a small ledge in to make up the difference. Any ideas would be greatly appreciated!
Wishiwasatoptiler
I'd do what Alan says as you have to think those screws fix the bath need covering, do what Alan says and you have a flush wall so the tile will go them.
scotmk
Or just bring out the wall the same width of the bath but up to ceiling leaving the rest and make some recesses for putting things in...
Or the shelf/frame you made at end of Bath should have been lower by adhesive and tile width so tile finish would have been at the bath lip.
Martino
Or build the lip up one tile high and 50mm wider an tile it...the best looking end result will be to bring the whole wall forward so the bath fits perfect.....so many options....its like being in subway!
Spare Tool
Just had exactly same issue with a shower tray..room 1770 tray 1700, studed wasll to edge of tray out and added a neich for shampoo etc, and it didn't take any more space off the rom than was necessary..
Reply to Tiling Around Odd-sized Tub Space With Ledge in the Canada Tile Advice area at TilersForums.com
Bob Marley
