Tilemaster Tilemaster Grout
Discuss Tilemaster Grout in the Tile Adhesive / Grout Advice area at TilersForums.com.
You guys who use tilemaster ,whats the grout like mainly just grey or white flexi ,appreciatte your appreciatte your input cheers
I find both grouts easy to use, only problem I find is when grouting rectified porcelains it dries fast on the face of the tile, but stays to wet in joints,
I spoke to technical dept & they say knock it up as stiff as possible. Easier said than done without a paddle.
MW Smith Ceramics
The fl is rapid setting , that's what I use for porcs & find it ok, you get that issue with the fs but I just use it for ceramics.....
Time's Ran Out
Better to use a resin or paint whisking paddle using a cordless drill on slow speed. You can pick up those whisks for £5 and everybody has a cordless drill
If he's a tiler and he hasn't got a paddle then he ain't going to get a separate little grout whisk before he gets an addy mixer! And if technical say mix it thick then thick it has to be.
Reply to Tilemaster Grout in the Tile Adhesive / Grout Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
The saga of my hollow floor 50sqm continues. All tiles now lifted but there is adhesive around...
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
