Tile trim in 3 metre length?
Del
Does anyone know where I can find some plastic tile trim in a 3 metre length?
I'm tiling a frame around a bath tub that's 2.85 metres wide and runs from wall to wall. The front edge between the bath panel and the horizontal area needs some trim fitting to finish the tile edge properly, but so far I can only find trim in 2.4 metre lengths. I really don't want a cut line in the trim. Failing that, does anyone know any alternatives I can use i.e. non tiling trims?
9mm quadrant?....is this too big? can buy them in 5m length's at a place called nu-stock....superglue in place
Thanks. That's an option, but I'm not sure if I could get it fixed tight to the tiles like tile trim. There's no lip to hold it in place.
9mm is very flexible should stick fine with super glue, get the 2 part. activator and glue, will stick it deffinitly 🙂
Del,
Martino,
Del,
Martino,
