I have bought the homelux tanking system and are just wondering how I should go about sealing round and integrated shower and radiator pipes any advice would be much appreciated images attached
Homelux membrane kit?
They do actually sell pre made collars for things like that.
It's just a softer material.
If u've bought the banding to seal joints u can just make some from that, or use left over membrane.
Hi 3_fall
thank you for the quick reply there is 3 silver screw on parts for the control knobs should I fit them and cut the membrane round them and use silicone to seal the membrane to them? I say kit I bought the membrane for floor walls some corners and the joint tape
No, no need to go that far, u generally rely on cover plate to fully protect the diverter.
Just take membrane up to the controls.
Basically just cut holes in membrane so the controls poke thro!
OK cool but doesn't that make tanking pointless if you get a tile leaking above the shower mixer it will run behind the plaster board? Or am I just being anal anyways thank for all your help I'm sure I will have more questions
Often the shower mixer body needs to remain accessible (by just removing the front cover plate) so that filters in the body can be cleaned/replaced and so in these cases you can't really tank tight up to the "tap/control" bits (I don't know if this is the case with the one you have fitted). In practice very little water is going to be hitting the wall above the shower mixer so providing the grouting is good quality and the cover plate fits well I don't think you will have a problem.
Personally I'd be more worried about leaks from pipes behind the plasterboard!
Hey all
I have just found out that Chris Emery from Schlüter-Systems Ltd will be at Tileflair in Reading on Wednesday 15th May for a Q&A session!
So if you are in the area see if you can pop...
Created a new forum category for Tilers' Talk covering all other countries. Please start a new thread of your own by clicking THIS LINK. (you need to be logged in to post)
I'm looking for a few Porcelanosa Town White Polish / Pulido floor tiles - badly laid in my new build and a few have cracked. One or two would be useful, I could use up to 8 to allow for some wastage.
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Another First for UK Tiling Forum; Crossing the 1 Million Posts Mark Soon
It appears the other UK Tiling Forum is using a Free WordPress (that’s fine) but they went for wpForo instead of bridging...
