Discuss Surface prep for floor and wall in cloak room in the Canada Tile Advice area at TilersForums.com.
serval
Hi all, im re fitting my my small wc/cloak room and plan to tile the floor. ( about 2.5 m2)
The existing floor is concrete and it is pretty flat for the most part. However there are some areas that are uneven and likely to give me problems. so i wanted to check what the best practice for preparing the floor before i start tiling?
Even if the floor was perfectly flat, would you tile directly onto concrete? or does some other sub floor need to be installed first?
Also got a wall and some boxed in pipe work that im going to be tiling.
The wall is painted plasterboard and the boxed in area is 12mm hardibacker.... do either of these need any special surface prep?
Interested to hear what you guys do in this situation
Thanks in advance
serval
Here's a couple of pics.
The floor has a few areas that are slightly uneven by around 2mm at most.
Would i be able to use additional adhesive and back butter the tiles to fill out any uneveness or am i better off self leveling the floor first?
WetSaw
That deep hole in the corner will need filling, hard to tell how deep it is from the photo. The rest of the floor just use primer before tiling. The paint needs to come off the walls.
serval
Thanks for.the reply
That uneven bit in the corner is about 8mm deep.
Would you use self leveling screed to fill that in?
Also what type of primer should i use on the floor?
Spare Tool
For what it is might as well get a bag of leveler and fill all the dips in, got to mix a full bag up so might as well use it, just pour and pull a straight edge over the floor... Try and stick with the same reputable brand throughout, so prime with the same manufacturer as your leveler and adhesive..
serval
Cheers.
What about a suitable adhesive that i can use for the floor and wall alike. Got some primer g so wanted to stick with mapei.
Wouls adsilex p9 be suitable?
Spare Tool
Personally I wouldn't use anything other than an S1 adhesive so if Mapei would go with slowset keraflex..
serval
Have used keraquick s1 before and got on fine with that.
Slowset might be better this time as it'll be my first attempt at doing a floor so the extra time should be good
Reply to Surface prep for floor and wall in cloak room in the Canada Tile Advice area at TilersForums.com
Teejay
