Spiked Rollers now at Trade Tiler
G
Gazzer
At last our favourite tiling tool supplier Trade Tiler has spiked rollers, for anyone who levels floors these are a must.
Its another tool that i wouldnt be without now. It will get rid of air bubbles and leave a beautiful smooth floor and that means less hassle when it comes to tiling.
TradeTiler.Ltd Miscellaneous Mixed Items
Thta's good news but the spiked roller won't do the job on it's own. Any chance of some wiping blades to compliment the rollers Dave?
Very true Sully, i havent used "wiping blades", i just trowel over using Mapei leveller, which i feel is the best leveller i have ever tried and then roller it over. Its given me better floors than ever before but always willing to try a better method....so what do you say David ? Wiping blades ?
I used to do that too - but after using wiping blades, I can only say that troweling levelling compound compares to applying butter on toast with a shovel. No offence intended but the blades really are the way to go. Get hold of some - they make the world of difference:thumbsup:.
Andrew
Thanks Andrew, maybe you can expand on this process and maybe a few photos ( Dave likes photos :grin:) So we can all understand. Many thanks.
First time uploading images but hope this works.
I must also admit that I have only recently been thought this method and completed two jobs but didn't take pictures of the results. On my second floor which I was preparing for tiling, client was so impressed with finish that he jokingly suggested that we should just paint floor and forget about the tiles:lol::lol:
The spreader handle is approximately 60cm wide and the blades come with either 3mm or 5mm teeth. Measure floor area and calculate required amount of levelling compound. Prepare bags, water quantities needed in measuring buckets and buckets for mixing. You'll need to be efficient and mix buckets as required, as you don't want the compound spread on the floor to go off by the time you have your next bucket mixed and ready to go. Easier with two people but allowing that you are working alone, get everything in place in order to avoid delays. Working from the furthest point with first mix, don't pour the entire mix in one go - only work over areas that you can reach. Pour sufficient amount on floor and spread with your spreader. The teeth on the spreader (5mm or 3mm) will find their depth helping you to achieve a flat floor. After say spreading a full bag, then use the spiked roller to remove any airbubbles.
Sorry - I'm a better tiler than I am a writer so hope this makes sense. Chris Roe was my master teacher and he may want to add some input here / refine my description of methods used.
Andrew
Gazzer,
disco,
Gazzer,
disco,
