Discuss Removing Transit Wax from Polished Porcelain in the UK Tiling Forum area at TilersForums.com.
K
kevg
Been trying for the past couple of hrs to remove the transit was on my b&q beige polished porcelain tiles. I have LPT Grimex and vie used 1:10, 1:3, 1:1 and even undiluted. Nothing I do is removing it. I have tried a rubber bristle scrubbing brush, a normal plastic scrubbing brush, a nylon pad, and a normal cloth. I sometimes get a tiny little mark where I see the polished surface below, but at that rate I would have my floors done in 2 years lol.
I do have my car rotary polisher that I may use, but surely it can't be that hard to remove ? Am I doing something wrong ?
White Room
Re: Removing Transit Wax from Polishec Porcelain
You are sure there is a wax on it.
K
kevg
Definitely a wax on it, when I run my finger nail over it, it lifts it off.
Dave, I've applied it neat by simply brushing it over the tile and letting it sit for a min or two, then gave it some welly (elbow grease) then left it sit for 10 mins. Then used wet sponge to completely remove. I then buff it dry with a towel.
K
kevg
If I don't Scott, then it's very very hazy.
What I do is remove a little with my finger nail, then look at the light on my ceiling through the tile. It looks crystal clear. Then I move my head to a bit I haven't touched and it's all hazy/blurry so I can safely say it's supposed to be removed.
K
kevg
K
kevg
Scott: just stays the same, all hazy.
Sometimes you'll get tiny bits of the polished surface come through.
Scott
Try and polish it up with a clean cloth, make sure you dont use a dirty bit on it again. When sealing polished porc it can take a LOT of cloth as the cloth gets bunged up with the sealer and then contaminates the tile. I use lots of kitchen towel of blue paper towel
K
kevg
It's kinda crusty, I've just used a sharp flat bit of plastic and it removes it, it's defo not greasy like you would expect from wax, this is crusty.
Reply to Removing Transit Wax from Polished Porcelain in the UK Tiling Forum area at TilersForums.com
