Discuss Refit Shower Enclosure Silicone Sealant Advice in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi All, we have recently had a new shower enclosure fitted and wanted to check whether the inside vertical profiles should be silicone sealed as a "belt and braces" approach to prevent leaks? The instructions only state to do the outside and the bottom of the door only:
The fitter has stated we should be ok as per the above instructions, however our previous enclosure (which was a sliding door as opposed to the hinged one we have now) did have silicone up both inside verticals and that was advised:
I have attached pictures of what the new enclosure look look like and there is slight gap between the wall and vertical profile due to the textured tiles:
Would anyone know If this ok (as stated by the instructions, but maybe on the premise that this would sit flush?) or should we add sealant between the wall and profile?
Reply to Refit Shower Enclosure Silicone Sealant Advice in the Tanking and Wetrooms Forum area at TilersForums.com
Lowpaul22
