Discuss Protilers - latex screeding a floor in the Canada Tile Advice area at TilersForums.com.
P
Protilers
Evening all....just got back from screeding a 45m2 floor......
it was a really rough floor coated with a Silka DPM.........
All the materials used were from Weber...........as per spec......
first off we used Weber PR360 primer..........
here is how it went:
here is how it looked after it has dried.....
its a really good floor and I am not going to get to tile it...........(gutted!)
this job was completed for a major wood flooring contractor in London..........
what do you lot think?
all the best
Lee
P
Protilers
it looks like it has had a Damp problem ! to me ,why did they use pitch -on the sub-floor lee ?
It did have a damp problem DPF.........and there has been a plastic membrane installed and then a floor screed (S&C).....then they have applied a liqud membrane with aggrigatte.....and I have gone over that.....
but I have to be honest..........I have no idea what "pitch" is?
all the best buddy
Lee
1,068
we work nationwide .
Pitch (resin) - Wikipedia, the free encyclopedia it was used all the time years ago when i used to screed houses , usually roofing contractors used to boil-it -up and then they applied it to the oversight concrete with an old mop-head , it looked just like your floor as they sometimes used to dash sand into it to give it key ,then a day or two later we would screed onto it ,that was the DPM !.....
P
Protilers
well DPF...its a modern equivilent......same REMOVED different day!!!!............
hehheehheeehheheeeee.........never heard the term "pitch" tho'......................
would you be interested in helping me out on a job?.........its over 1400m2......and part of it is a pool an jacuzzzi.........in W2, London.........I will understand if you are busy.........pm me..........
Lee
widler
1,328
England
Looks like they are going to carry on having a damp problem, looks to me they have plastered down to floor !
Ajax123
1,213
Lincolnshire
Depends how it is tanked and where the walls DPM is in relation to the floor. Looks like new plaster where skirtings have been removed
1,068
Yes i was wondering myself as i'am a qualified dam-proofing operative, did it years ago, and we were always taught to remove the plasterwork at a hight of 1M all around the room and that just guessing the scale against things in the rooms is to low, also there appears to be salts comming -out on the walls where its not been taken off properly ( trouble there already ) the reason you remove 1m high is because rising damp can never go any higher that 1m ,so you always assume that its infected to that hight !!!...........
Reply to Protilers - latex screeding a floor in the Canada Tile Advice area at TilersForums.com
