Discuss Old house, traditional pine floorboards, 6mm ply, plus Ditra in the Canada Tile Advice area at TilersForums.com.
dynamictiling
568
glasgow
ditra ok,without seeing the floor every job is different. 6mm ply- personally I don't touch the stuff with tiles, under any circumstances. Even tiling onto 24mm marine ply, I wont overboard it with 6mm ply.
Time's Ran Out
I would say no!
But it depends on the size of the floor, how much deflection is in joists and the weight expected to go on top of the floorboards.
British standards is 15mm exterior plywood however there are better substrates available these days .
If it's just a 1metre wide hallway you may find 6mm hardie boards suitable. But if it's a 30 metre kitchen with 2 ton of granite worktop then a structural engineer may be required.
Busybee1
Thanks for the responses. It's a kitchen, 15' x 21'. The original floorboards have been over boarded with 6mm ply nailed down, then some very sticky stuff, then ditra matting, then adhesive, then the tiles. They are large tiles, about 10" x 20".
The tiler laid the tiles this week. A couple of other things made me question the work, but now I'm getting worried about the ply base thickness.
Does using the ditra mean you can use a thinner base? Are my tiles likely to crack?
Busybee1
I should add that the end strip of the kitchen ( 15' x 6') is a part concrete, part tiled base, where levelling compound was used, and going across the different floor types was the reason for ditra.
Busybee1
I know whitebeam, I started worryng about that too. Is it a really bad sign? There were quite a lot of nails, very regularly spaced.
Reply to Old house, traditional pine floorboards, 6mm ply, plus Ditra in the Canada Tile Advice area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
