Discuss Mitre L cut metro tiles in the Canada Tile Advice area at TilersForums.com.
31
UK
Sorry, I should have said, I'm referring to external corners with a mitre. I will be using a trim for the top edge of the splash back which is only 400mm high above the worktop.
I
Italy
I give up, I volunteer,
send me 2 packages of metros tiles,
I cut them all at 45 degrees
(the old ones called them jolly) while I eat a sandwich
at midday....:) :)
Waluigi
Akemi Poly Soft Resin
Akemi colouring paste to achieve a colour match.
Use a diamond polishing block to sand back. You’ll need a few different grades of Pad.
If mixing in colours get the colour spot on before adding your hardener. Mix up a big batch of the desired colour and then take an amount away from the batch to then add to your hardener. The reason for this is to keep a consistent colour match. Also it’s good to have a colour match in case you need to infill areas.
Good luck!
31
UK
Good luck!
Thanks for the advice!
I think we'll be going for a white grout and resin to match the tiles - keep it simple. I was kinda hoping there would be some pre-mixed colours available on the market for simplicity.
Reply to Mitre L cut metro tiles in the Canada Tile Advice area at TilersForums.com
  • Poll
