F
Flintstone
I'm not sure there gonna work Marc with the bevel of a metro ?
Discuss Mitre L cut metro tiles in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
Yep may have a point there Andy.I'm not sure there gonna work Marc with the bevel of a metro ?
Manhattan grey would be ideal.
I did some duck egg crackle glaze metros last year with light grey Kerakoll epoxy grout
Any particular reason for choosing an epoxy grout Plan Tec?
Sorry, I should have said, I'm referring to external corners with a mitre. I will be using a trim for the top edge of the splash back which is only 400mm high above the worktop.
Akemi Poly Soft Resin
Akemi colouring paste to achieve a colour match.
Use a diamond polishing block to sand back. You’ll need a few different grades of Pad.
If mixing in colours get the colour spot on before adding your hardener. Mix up a big batch of the desired colour and then take an amount away from the batch to then add to your hardener. The reason for this is to keep a consistent colour match. Also it’s good to have a colour match in case you need to infill areas.
Good luck!
Reply to Mitre L cut metro tiles in the Tiling Advice | Tile Forum area at TilersForums.com
