Discuss It’s New tools tuesdays in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
WetSaw
..and it's made in Spain!
Waluigi
I don’t use Alibaba. I use AliExpress.
Might be worth starting a thread on it in the other section of the forum because we can’t discuss prices here.......
Waluigi
You’re right, They don’t cut as well as as the cheaper diamond coated bits or whatever they are called. The cheaper bits but the expensive versions of those bits cut nicely with water. That because they are thin walled bits. It really depends on the application though. Towel rad pipes and hot and cold entering a wall mounted cupboard are covered in metal shrouds so it matters less
I mainly use the vacuum brazed M14 bits on the smaller verieties (6mm) and they cut beautifully. Every bit as good as the expensive versions.
H
hmtiling
On
Be good if you add some feedback on them when you've used them, with images too please.
Started staying clear of the M14 bits, they don’t seem to be cutting clean enough unless you buy high end pieces.
I’ve moved back too the cheapest vacuum braised bits cos they’re leaving cleaner cuts
I've never switched from them not found I tile I can't get through yet and when working with guys who use grinder bits I'm quicker and leaving much neater holes
Reply to It’s New tools tuesdays in the Tile Tools | any Country any make any model area at TilersForums.com
Apatel
