Discuss Is My Bathroom Subfloor Good Enough? in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
J-S-Q
I am DIY refurbing a bathroom in my house and would be grateful for some advice...
The subfloor is T&G chipboard, nailed onto joists. It was previously tiled and had UFH but I have now stripped this. My plan is to install Warmup DCM-Pro, with 100mm Warmup insulation boards and then tile on top.
There is a certain amount of tile adhesive residue left from the old installation so the surface is a little uneven. I guess it has some bumps of 2-3mm. There are also a few small punctures in the flooring (see photos). What is my best way forward? Should I:
a) Crack on and glue down the insulation boards.
a) Repair the holes somehow and possibly apply self-leveling compound.
b) Rip up the chipboard and replace with plywood.
c) Something else?
Thanks!
Wayne Brown
The job will only be as good as the prep I would overboard with hardi backer first screwed down and sealed as their spec you then has a new stable surface to work off others may disagree . Kop
Reply to Is My Bathroom Subfloor Good Enough? in the Tiling on Underfloor Heating area at TilersForums.com
laattaana
