Mattt
Hey is cutting a hole in the middle of the tile for a socket. To thread the socket through the tile do you usually have to un-wire the socket with the hole in the tile being smaller than the socket.
yep, angle grinder is probs best as long as you don't overcut from the face sideThanks an is an angle grinder needed for cutting the hole in the tile?
Assuming the electricians have done the job properly, and working on the basis that it's a ring main circuit with 2 wires in the back of the socket, then there's no way you'll get the faceplate through the hole in the tile. Cut the hole in the tile to the size of the backplate, take the socket off the wall, fit the tile, grout, then refit the socket. Job done
wrong pal, done easy if the wires are long enough. Done it hundreds of times without removing socket face, not a debate on my behalf, just a fact.Assuming the electricians have done the job properly, and working on the basis that it's a ring main circuit with 2 wires in the back of the socket, then there's no way you'll get the faceplate through the hole in the tile. Cut the hole in the tile to the size of the backplate, take the socket off the wall, fit the tile, grout, then refit the socket. Job done
You mark the tile up to the back box that sits in the wall that ensures you dont have any gaps around the face of the socket, shouldnt really have a problem twisting the case unless wires are too shortHey is cutting a hole in the middle of the tile for a socket. To thread the socket through the tile do you usually have to un-wire the socket with the hole in the tile being smaller than the socket.
Why have you commented on this? Lol its from last xmas only just noticed lolAs others have said, if the hole is cut accurately then the socket will pass through easily.
Use a wallpaper scraper or similar to push adhesive all the way around the edges of the hole as this will give the tile a bit more strength and therefore providing you don't over tighten the screws should be no mishaps.
In case someone else is reading it with the same question.Why have you commented on this? Lol its from last xmas only just noticed lol
Work of art that mate.
Have you removed the sockets first, or were you brave and popped each socket through its relevant hole ?
