Hi from BernieA
  • Thread starter Thread starter BernieA
  • Start date Start date
  • Tags Tags
    usa
BernieA
Hi, In the past I've usually done my own tiling on Kitchen and bathroom walls but when I got an extension to my house a couple of years ago I decided to have Travertine tiles in the Kitchen, diner, sun-room, utility room and downstairs loo. It cost me a small fortune to buy the tiles and adhesives and to have them laid but they have been a complete disaster. I've tried in vain to get the tile suppliers involved in putting things right but they have refused, stating that I should have been aware that Travertine is high maintentance and new holes would appear continually. They maintain that their Travertine is 1st quality. I've looked at quite a lot of Travertine floors but never seen any as bad as mine.
I sealed the tiles myself using Stonefix satin tile seal which I believe is acrylic based. I have always cleaned the floor using a neutral cleaners recommended for marble/travertine etc.
My kitchen area looks awful. Around 40% of the tiles have either multiple small holes or else several large holes sized from 0.5 cm to 3 cm across and upto 1.5 cm deep. A kitchen bar stool has worn into the tiles on which it stands as if they were made from polyfilla. The first tile inside every enterance door has cracks in it - I presume this is down to insufficient adhesive at the interfaces. The dining area was floor boarded but covered with 20mm plywood which was screwed around every 4 inches as I recall. Worryingly there are now several places here where cracks have appeared which contnue through several tiles.
As you can imagine, my wife hates the site of it and would like to have it all ripped up. I'm retired now and couldn't afford this option even if I wanted to do it. She is giving me one last chance to try and save it before she brings someone in to cover it in cushionfloor. I haven't dared tell her that it will need covering in leveller or grinding first due to the lipping on some of the tiles.
I've decided to do the repair work myself where possible and will seek the advice of pros and more experienced diyers in Tilers Forum, so look out for my Posts.
Hi and welcome to the forum. Sounds like you have a big job on your hands good luck
Hello and welcome to TF..
Sounds like you have a low grade stone.. This is the down side of using cheap grades on floors..
hi,sounds like cheap travertine im afraid
also sounds like a rip out i dont see how you can sort or repair this especially if you have cracks also in the tiles now.
Welcome along. Did the company you purchased the tiles from provide the tiler to do the fitting for you? Also could you not replace the very worst ones and repair the smaller holes? If you could post some pictures it would help to see how bad your situation is. What is your location? It might be possible for somone to come and look at your floor to give you some advice, you don't want to cover it all over if it's not really necessary.
Thanks to everyone for welcoming me to the foum
I bought the tiles from a company called N&C Tile Style located in Leeds. The fitter is my son-in-law, who is also located in Leeds. Although he had been a full time tiler for around 18 months this was his first Travertine job. I live in Thornaby, Teesside.
The tiles N&C had on display looked very good. They described them as being 1st Quality which I took to mean very good, though I now know differently. The ones that they delivered were a mix of good and not so good, though obviously it van be difficult to tell for someomne who isn't familiar with Travertine. Someone mentioned that there was a regulation introduced a year or two ago aimed at stopping suippliers from selling low grade travertine as suitable for floors - Has anyone else heard of this?. I'm sure I wouldn'y have had many problems if I'd used it on the walls.
Obviously I cant really pursue my son-in-law but I'm sure he will help when he can, especially when it comes to removing some of worst tiles. He now works full time in a different job and has a young family so his help will be limited to an odd weekend afternoon.
I will start a new topic in the forum which I will call "Travertine Restoration Project". I will include photos as I go along. Look forward to your helpful inputs.
Many Thanks...BernieA
Hi from BernieA
Tags Tags
usa
BernieA,
BernieA,
BernieA,
BernieA,
