All. I'm trying to cut a 330 x 330 square tile diagonally into 4 pieces, to fit round a wetroom grid. Dry cutting doesn't give you a grout joint, so want to use wet cutter. On my cutter you can't use the guide, see photo, as the tiles too wide and at 460 diagonal its too wide for the bigger wet cutters I've looked at. Help!
