Discuss Hardiebacker - 6mm or 12mm? in the DIY Tiling Forum area at TilersForums.com.
Mossop
It depends on what situation you're using it in.
On a bathroom wall directly beside a bath which has an overhead shower. Timber studs. Tiles are the mini metro 7.5cm x 15cm tiles.
I presumed the weight of the 12mm thick board would be twice the weight of the 6mm board since both have the same dimensions. However, according to the B&Q links above, the 6mm board is 9kg whereas the 12mm board is 13.8kg.
I use alot of the 6mm backer board for overboarding floors but very rarely use the 12mm (just alot more hard work to cut and fix). Guessing you are matching the thickness of surrounding plasterboard? Aquapanel is lighter, easier to cut and fix and a similar price. (Im not a aquapanel salesman btw )
Reply to Hardiebacker - 6mm or 12mm? in the DIY Tiling Forum area at TilersForums.com
Bob Marley
