Dewalt D24000 hints / tips and accessories thread
It has both.
I would have preferred it if they also had 1mm markers.
But it does work as a rough guide, which should be double checked with a tape measure. (or laser if one is fitted!)
It is one machine that would be worth the effort to import.
I've never had such accurate and consistent cuts in my life.
It is an absolute joy to use, and very easy to clean. (with hose pipe!)
I am having to rethink some of my (large tile) cuts due to the bridge arm on the left.(used to a overhead bridge saw)
Otherwise, it is near perfect.
Have you got around to doing a tap mod to the water supply and removing the clip. I keep meaning to get a tap from the brewery supply shop.
I have fitted a better water flow system to mine today ie, a small inline tap. Yet to see how it performs.
Well for the couple of £ it cost, Its a good addition to the DW24000. While it does the same job as the flow clip it is a lot easier to use.
Re: Dewalt D24000 hints/tips and accessories thread...
I bought one of these cutters 3years ago great machine but I lost the guide that you use to do numerous cuts the same size,does anybody know where I can get a replacement.ta
They cost £53.15
Check out post #20 of this thread.
Click the link provided. Your item/part is "251"
Paul
fulabeer,
fulabeer,
