Guest viewing is limited
Decent portable wet cutter??
Tim the Tap
Hi.
I am looking for a decent affordable (£100ish) portable wet tile cutter. Could anyone recommend a brand??. No Plasplugs🙂
Seriously thinking about a: 1021 SIRI Briccolina.
Anyone have any experience with this make and model?
Cheers in advance..
Just for the record I have no affliation with the above companies link..
Just got these in yesterday to trial and must say very impressed so far, They come with a handy water tray that is also moulded into the handle so you can basically pick it up and carry it like a briefcase, also the water doesn't run of like the rubi etc making a bit of mess but is caught and retained within the tray.
I will be putting it through its paces next week so will let you know.
i use to have a briccolina yrs ago was a dam fine cutter...but burnt it out eventually and switched to rubi cutters now........dave..
Review on Wet cutter:
I found this wet cutter superb , from a portability view its faultless as mentioned before it sits inside its own casing and the handles are moulded for easy transportation. When starting it it kicks straight into life as apparently the older ones could take a while to gain full momentum.
This cutter is ideal for kitchens and the smaller tile sizes but as I found out is also effective on floors (I cut a 12ml thick piece of slate )
Down side: I know theres always one! The wheel that comes with it has a straight through bolt attachment and is the only wheel you can buy for this paticular cutter although (and i'm not sure I should be saying this but what the heck!) you can get other wheels and manually drill a hole and fit it on no problem.
So in a nutshell a decent little wet cutter thats ideal for areas where space is an issue and you want a tool thats not only easily portable but sturdy with it.
My only advice is don't have your wetcutter at thigh level on a work bench as afterwards it will look like youv'e peed yourself as one of the guys found out today much to the amusement of the others, and thats certainly not a look you want to share with a client!🙂
Nice one Kenny...lol....greeting client with a map of India on your crotch is not the best look.... ps thanks to kenny for being my spellchecker..pmsl
Great review. Do you have any available to sell? If so how much??
The only place that I can find to buy them from is contractors direct..
Cheers
Cheers
Got one of these myself, excellent piece of kit, clean enough to use indoors!. Got mine from PTS training but Contractors Direct are very competative.
Grumpy
Siri also now do a "specific for porcelain" blade, but I have just done a floor with 10mm 600x300 porcelain and it had no problems at all with the standard blade.
Grumpy
I was one of the guys that used this cutter on diamonds course.And it was very good.But for some stupid reason Ive bought a plas.Should only be a couple of weeks until its in the bin and then I will be down to Diamond to buy a Briccolina.
Thanks for a great course Kenny,Vinney,and Jay(littlehampton Daddy)
I have done a number of jobs so far with the Bricci and its been brill, light ,portable and small to transport from one job to another.
Diamond training do them by the sounds of it, also, got mune from PTS warrington when I did my training. Also CDeuro.com though you would need to specify UK fittings.
Grumpy
Tim the Tap,
Yorkie,
Tim the Tap,
Yorkie,
