Discuss cuts with wet saw in the UK Tiling Forum area at TilersForums.com.
smokey1234x
any1 hav this problem
the cuts u do with wet saw u dry it with a rag just stick it with addy on wall, need 2 tak it off for a bit of back butter,then realise the addy didnt stick 2 tile with red dust from the cut on the wet cutter.
when u cut a tile in wet it still will b damp when the addy goes on or u would b there all day
grumpygrouter
Can't sasy that I have had that problem, but I do wipe down both sides of my tiles after cutting.
Grumpy
F
frogeye
I have used wet cutters on my home projects and used the tiles almost straight away. They haven't dropped off yet, however, when I did my course and after finishing each project it came to remove the tiles, I was very suprised at how little adhesive had stuck to the tile. I would suggest that it is only a small coverage on the back of my wet cut tiles in my kitchen, but mostly the grout that is holding the tiles on.
In future I will be planning my wet cuts as far in advance as I can and giving them some serious drying time - how long I don't know, but at least I have seen the results of using wet tiles. I will put them by a heat source eg a radiator - any thoughts?
frogeye
smokey1234x
not sure if its because the tile is still damp when addy is on it,think its more de do with the orange dirty water that be's in the wet cutter after a lot of cuts
smokey1234x
wet cuts
1 simple question, when all u's tilers out there do a wet cut do u stick tile 2 wall right away with a simple wipe with clothe or do u wait till tile is 100% dry
just wondering
DHTiling
Dry it off and backskim the tile and it sticks no probs....wet tiles wont stick to dispersion adhesives very well....
GazTech
If you clean the dirty water of with sponge and then dry with old towel....tile back is ready......Gaz
If you fail to prepare...then prepare to fail.
Reply to cuts with wet saw in the UK Tiling Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
