Builder wants to inject apoxy resin
TeaAndToast
Hello,
We got a new build and quite a few floor tiles in the main bathroom and en-suite rock back and forth under foot, thus the grout has cracked in many areas. After a little research I thought it was a lack of plywood base as it feels springy under foot and a few tiles aren't level. But the builder assures me there is ply down as he has seen it and its just that the tiler didn't use a rubber base.
He wants to inject an epoxy resin to fill the voids. I spoke to a tiler without seeing it who feels it should be lifted, and some of the older posts on here advised against using epoxy resin.
Are there times where this won't work and what do I look for if a tile is lifted for inspection?
Thanks for the read
If a few of the tiles aren’t level now, putting epoxy resin under them won’t make them level after.
That procedure was tried with uncoupling membrane that debonded but I believe it was an extremely expensive exercise.
Yours just sounds like poor subfloor preparation and needs removal and replacing.
You've answered your own question. If there's deflection ( bounce ) in the floor, tiles aren't going to survive long.
I've never heard of a rubber base for tiling on to so I've no idea what the builder means by that.
Rubberised adhesive to allow for movement.
Some are the tiles are a fraction high and low. Not really noticeable to the eye but if drag your foot you'll notice. I dont want to be over picky either.
Get it all up and redone correctly! There’s no miracle cure in a tube I’m afraid, despite the builders wishful thinking
Thats what im thinking. Is there any signs i could point to as this not the correct option?
Put a full glass of water on the floor then walk around. If any spills out the floor isn't solid enough.
TeaAndToast,
TeaAndToast,
TeaAndToast,
TeaAndToast,
