tony76
Hi all, i am about to start tiling my bathroom walls , and i want to tile it brickwork style, i was wondering if anybody could give me any advice on starting this,and setting out, the tile size i am useing are 361mmx276mm, and 9mm thick, and going to use a 3mm spacer, as i want to tile the floor in the same tiles to
any idea on where i should start from? i was going to start 1 tile up from the bath ( although it will be about just over 3/4 of a tile, as the bath for some reason isnt level all the way around, would this be ok, or should i start 1 tile up from the floor?
also i believe the corners can be a problem with this style of tiling,any tips about that?
many thanks
many thanks
