H
hairyhobo
hello all, im going to give tiling a go in my kitchen. But i was after some advice on where the best place to start on each wall and what to do around the window.
Im planning on using 300 x 100mm tiles, which would be half bonded on the walls. I have 300 x 300 floor tiles which have been half bonded, so not sure if that matters if it matches or not.
I also wasnt sure how to tackle the window sill, as in would i carry on the half bond across that and not worry the tiles would be the other way round compared to the tiles that will be on the wall either side of the window (if that makes sense?)
Also where is the best place to start on each wall? Would I just start from the centre of the window wall, or the centre of the window and work out? and the same with the wall to the left of the sink (1st pic), am i best starting from the centre and working out or from the left edge and work towards the corner so more of the funny cuts are hidden in the corner? and then the same with the side that has the hob on (splash back behind it), would I start from the splash back and work backwards towards the corner?
I am a complete novice and any advice will be amazing, thanks
