Discuss Advice on Professional tiling tools in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Boggs
I really want to know where this place is now!
Dumbo
Thanks John.
I understand where all this is coming from and believe me If I told any of these members in the forum/Tilers where the job is they would run a mile and would not be interested one bit!
We all need work and sometimes we can't pick or choose where that job is coming from!!!
Don't be mistaken we are not touting for work , what we are saying is if they are tilers they should have their own tools , or if as John did in Norway, they should be able to tell you what they want as Antonio said. Which leads me in my best Sherlock Holmes to deduce they are not tilers .
Time's Ran Out
We are here to help all standard of participants in our noble art!
At the end of the day we all want to see a job well done.
So the tiles are
400x400mm and 250x1500mm both 10-20 mm thick
Basic tools
Cutters - angle grinder with 2-3 good quality porcelain cutting discs.
Chalk line.
Spirit level/laser
Spacer pegs 2-3mm
Buckets,sponges, polishing cloths.
Pin hammer
Serrated trowels 6-12mm depth
American squeegee
Anything else is a luxury!
So the tiles are
Basic tools
Chalk line.
Spirit level/laser
Spacer pegs 2-3mm
Pin hammer
American squeegee
Hi,
Thanks for the reply.
This is a medium size house and manual cutting will take too long (I presume)and don't want to stay too long out there.
Any idea of makes on best(mid range) Electric Wet tile cutters, not too expensive(I have seen prices in the GBP 600 range)!!
I plan to hire a power generator while out there for the power needs!!
G
GoneGuy
Hi,
Which ever wet saw you purchase make sure you buy the appropriate blade for what your cutting and invest in a quality brand name
WetSaw
Hi,
Manual cutters are generally faster than wet cutters. If you want to cut a 1500mm tile you're going to need a big, and therefore expensive, cutter. Alternatively, an angle grinder, steady hand and decent blade will do it.
On one
Every Architect I have known, knew everything about everything, couldn't tell them nowt!
Albert
Hi,
Manual cutting is a lot quicker than a wet saw
H573
I work in remote areas too sometimes, usually with no access to electricity. Generators fine.
Get yourself some good work lights. If you want to get the job done you’ll be working late. And they probably won’t have lighting if my experience is anything to go by.
Preferably rechargeable battery ones if possible
Hmmm!!
Wonder how much Architects are loathed !!!
Hi.
so can you recommend one and accessories I would need?
Hi.
£600 isn’t a lot of money for a cutter.
Seriously, speak to the Tilers. Send them the spec of the tiles and ask them what they would like. At the moment it sounds like someone is trying to get unskilled workers to do a job that requires skill which will only end one way.
Hi All,
Thanks very much for the advice I got from this forum.
I ended buying the Flex CS60 with the 1.80m guide rail and some diamond cutting blades.
Now, this wet saw has to be plugged to a pressurized water mains as I understand it.
The problem is that I won't have that luxury as the site is remote so I was looking for a small immersible "wet saw pump" to go with this machine, ie one that I would immersed in a bucket/Plale of water that would be feeding
the saw as I cut.
Any ideas as to what pump to get??
Would this do :Rubi Water Pump DW DU Wet Saws 240 volt
Also, I am looking for a budget laser tile leveler
Would this do :ProNivo PNTL 45 Floor Tiling Laser With 90 & 45° Lines
Any other items you think I should get in light of my above project??
Urgent please as I want to make the purchases.
ok agree,
but it would be better if they were the tilers interested in the work
to say what they want.
or not?
if I understood the question correctly :)
Antonio,
It just occurred to me that you might be interested in taking on this job as my client bought all the tiles for this Job direct from Italy,1st choice!!!
I am looking for a very professional Tiler to work on this Job so if you're interested, reply to this post!!!
Dumbo
Hi All,
the saw as I cut.
Antonio,
Where is this remote location .
Reply to Advice on Professional tiling tools in the Tile Tools | any Country any make any model area at TilersForums.com
laattaana
