Discuss Advice on old tile removal in the DIY Tiling Forum | How to tile area at TilersForums.com
Jag877
Hi
I’ve removed old tiles in my house and there is the old adhesive behind it.
In some cases it fell off when I was taking off the tiles.
I’m not sure whether to take this off or not, would you have any advise on the best way to remove this please?
We are planning on getting in a tiler to put in new tiles
John
Advice on old tile removal | TilersForums.com Filename: {userid}
1. Use a chisel to chisel slowly, and it is relatively fast to clean up. Break it into pieces and tap the bricks on each side lightly to find one with an empty back, and then pry off the tiles one by one from the side (use a flat shovel or other hard metal tools with a flat mouth).
2. Professionals use electric shovels, it is easier for professional technicians to use electric shovels to clean up, remember that the heads must be flat. It is an important tool for smashing tiles. If a traditional hand hammer is used, it will affect our entire efficiency and function. Therefore, it is more convenient and practical to replace it with an electric pick, and it can also ensure that it can be easily removed for you within the specified range.
All advertising can be removed by subscribing.
This ad should no cover content, please click this contact us with a screen print if it does.
Reply to Advice on old tile removal in the DIY Tiling Forum | How to tile area at TilersForums.com
Similar threads
  • Question
I would definitely prime everything and also tank the shower area, mapei aquadefense is good and is ready mixed...
As they are dot and dabbed there is no way anyone sensible is going to recommend what you propose. Take them off and...
Your plasterboard looks as though it is skimmed and painted? If so the weight limit is 20kg/m2 and you also need to...
Shouldn’t be too much of an issue However if concerned I would Abbrade the surface (scratch the top layer off)...
Latest Post
Thanks for visiting TilersForums.com, formerly known as TilersForums.co.uk.
Search Forum
