Discuss Advice how to cut out a square hole. in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Pritch
Hi
Could anyone give some advice on how to cut out this flush plate that falls in the middle of the tile?
Time's Ran Out
Drilling the corners is not something I do - just straight through with the grinder then hit it with my pin hammer - have I mentioned my pin hammer before?
I
Italy
depends on the type of tile, ceramic or porcelain.
if it's porcelain, lately I do not make holes in the corners,
cut directly on the front and round the corners with a finger bits.
thus I avoid breaking the tile during installation and even after.
Pritch
Ok thanks for the advice
Just a quickie......
Should the tile cut be against the trim or the wall?
Also, are corners outside wet areas just grouted rather than silicone?
Albert
What trim? you asked about cutting a square hole in the middle
of a tile
Pritch
Hi
It was just a quick question.....didn't think it was worth starting a new thread for.
Its aluminum box trim.
Reply to Advice how to cut out a square hole. in the DIY Tiling Forum area at TilersForums.com
laattaana
